delete fdb mac-tracking entry
delete fdb mac-tracking entry [mac_addr | all]
Description
Deletes a MAC address from the MAC address tracking table.
Syntax Description
mac_addr Specifies a device MAC address, using colon-separated bytes.
all Specifies that all MAC addresses are to be deleted from the MAC address tracking table.
Default
The MAC address tracking table is empty.
Usage Guidelines
None.
The following example deletes a MAC address from the MAC address tracking table:
delete fdb mac-tracking entry 00:E0:2B:12:34:56
This command was first available in ExtremeXOS 12.3.
Platform Availability
